LarryJM
Nov 18, 2013Explorer II
VAfan wrote:SCVJeff wrote:
Got any links?
Other than very expensive professional equipment, I have played with two signal hunters. One dis the Winegard SensarPro that works really well. The other is a small handheld spectrum analyzer that scans and displays even faster than the Winegard and shows the entire spectrum on an LCD display. The Winegard is about $75, and the other about $250. But they both do an excellent job
This is an example…..
http://www.amazon.com/King-Controls-SL1000-SureLock-Digital/dp/B0045E3MHK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1384819837&sr=1-1&keywords=signal+strength+meter
Just realize that meter you linked to won't tell you which channel is where (i.e. direction). It only shows you where the strongest group of signals are. I think for under $100 the Sensor Pro is the best you can do. In tunning my home OTA antenna using my DigiAir meter I can see about 1db strength delta in only a change of around 5deg of antenna direction.
Larry
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
