westend
Mar 18, 2017Explorer
I've put carpet in vehicles. A lot of it can be cut or formed as you go but templates are like gold, just allow for extra.
If the carpet is jute backed, a spray down of water will loosen it so forming is a snap.
If the carpet is plastic backed or has a pad attached, heat can help but pressure and fastening while the adhesive sets is more typical. You can also fold or roll some plastic-backed carpet to loosen it before installation. All carpet has a weave and weft (backing is laid in two opposing directions) so work it in two directions.
If you have a carpet with dense pad, you may have to make some cuts in the pad to form around tight radiuses (radii ?).
Good luck with the installation!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
