64thunderbolt
Jun 10, 2013Explorer II
If you are doing 10 mph & the eng screaming the stock fan is moving more air than any elec on the market. Is the fan clutch in good cond? Rad? Tstat? Also if you will be using both fans there may be a terbulance issue.
Completely drain & I mean COMPLETELY drain the cooling system and instal Evans coolant.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
