pianotuna
Aug 05, 2019Nomad III
Hi,
I'm in a class C.
I mounted the inverter behind the driver's seat. That kept it within four feet of the battery bank.
I fished wire back to the shore power cord "hatch" inside the RV.
I placed a 30 amp receptacle inside the hatch.
This way nothing is left outside to get wet, or to grow wings.
I shortened the shore power cord to 4 feet, put on a male plug, and added a female plug to the left over shore power cord.
I fished a dedicated inverter outlet in the kitchen area so that I can have extra power in the kitchen--and that can be used at all times, without "powering up" the rest of the RV.
I prefer manual systems, so I set the fridge to propane and leave the OEM converter unplugged on the 120 volt input side.
The unit I installed is an inverter/charger and has pass through capabilities.
I'm in a class C.
Bigfoot2005 wrote:
Hi guys
I am thinking of installing an inverter inside the front cargo hold and running a wire to the outside to a 30 amp receptacle so that I can plug my trailer plug into it when I want to use the inverter for power.
Has anyone done this? If so, can you share some pics and how you did it?
Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
