kfp673
Jul 17, 2020Explorer II
ernie1 wrote:
I did what you are thinking of doing and it"s worked out extremely well. However, one of the biggest problem in doing this is that most quick connect fittings are too long to fit under your plastic cover unless you drill a hole in it and that looks really hokey! I looked around and found the shallowest fittings I could find and swapped holes with the tv cable connection so that the hose connection would be towards the center of the plastic cover where there is a bulge and it fits and works well.
Thanks! Do you have a link to the one you used? I like the one iamichabod shared but want to review all.
Also, I noticed they make them in reverse where the male end would attach to the camper instead. Cant seem to find dimensions listed on any though so it's touch to tell which would fit better. click
Thanks again!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
