Dutch_12078
Jul 17, 2020Explorer III
IB853347201 wrote:IAMICHABOD wrote:
I like This one the male end fits better and is shorter than the other types. It may fit behind your door.
I use quick disconnects on everything.
X2
X3... I went through several cheap plastic and brass plated QD's over the years that used a modified hose washer for the seal. Even the least amount of dirt or mineral buildup caused them to leak. The brass QD's linked use an independent O-ring as shown that seals well and can be sourced at most hardware stores if damaged. I have a small package of spare O-rings I found in the loose hardware section at an Ace Hardware, but I haven't needed to replace one yet.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
