JJnLillyExplorerJan 01, 2017Awning HelpWent to put up our sun screen for the winter now that we are settled at Tampa and found that the replacement awning installed at it seems that the end caps were put on wrong. Is there a way to rotate ...Show More
Old-BiscuitExplorer IIIJan 01, 2017No the end caps were NOT installed wrong.Common for end caps to be installed W/O opening lining up with grove in roller tube so awning stays secured.Get 1/4" drill bit and drill motorAt one end of roller tube drill into grove at an angle making a slot to use for installation of Sun ScreenSimple.....and not messing with end cap/awning springs etc needed
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
