dalefuji's avatar
dalefuji
Carefree awning
I have a manual Carefree Awning and have problem when closing.
I hit the unlock switch and awning rolls up and goes under aluminum
cover. When I pull on the top near rear end it seems locked. When I pull on top at front end it comes out approx. 6". I checked canopy at top in aluminum cover and it is centered and set screw in each end to keep from moving. The canopy in rail is centered without screws in each end. I tried moving canopy slightly one way and then the other way in rail with nothing changing. This just occurred recently. I have the rail locks halfway down on both rails but doesn't stop top from moving out 6". The only thing left, in my opinion, would be to tighten spring in front end of rail!
Any suggestions!
