JJnLillyExplorerJan 01, 2017Awning HelpWent to put up our sun screen for the winter now that we are settled at Tampa and found that the replacement awning installed at it seems that the end caps were put on wrong. Is there a way to rotate ...Show More
Chris_BryantExplorer IIJan 04, 2017FWIW, rotating the rear end cap is trivial- there is no spring tension on the cap itself. Rotating the front one can be a pain on A&E.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
