Went to put up our sun screen for the winter now that we are settled at Tampa and found that the replacement awning installed at it seems that the end caps were put on wrong. Is there a way to rotate ...
Yes, basically. You'll need to slide it and the torsion assembly out of the roller tube, just enough so the endcap is free of the roller tube. Then rotate and push it back on. As I recall there are some 'stops' on the inside of the endcap that will keep it from rotating when it's all the way on. That's from what I can remember, if I'm wrong someone please correct me..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
