theoldwizard1's avatar
theoldwizard1
Explorer II
Jul 09, 2020
Azdel or equivalent
I am looking for a sheathing material like Azdel that contains no wood fiber so that it can not rot.
I would go with Azdel, but it is not sold "retail" anywhere. Authorized RV dealers can get it for repairs but I would be afraid of what they would charge !
  • Gjac's avatar
    Gjac
    Explorer III
    theoldwizard1 wrote:
    wanderingaimlessly wrote:
    They have basically no structural strength, at least in the vervion I used, but there should be others which may work for you.
    These are used for sheathing, so I need shear strength to prevent the walls from racking front to back.
    I'm not sure what your application is but in general most any resin that is fiber reinforced will be good enough for a side wall of a MH. Azdel is just a thermoplastic material(polypropylene) and most Azdel products are FRP . Epoxy reinforced with a woven fiberglass will be stronger. Woven FG will be better in shear and stronger in general(tension,compression,bending etc) than random fibers like Filon. Azdel, Lamilux, FRP epoxy or polyester will all work for sidewall. It will be next to impossible to get mechanical properties like shear strength from their web sites so you will have to call and talk to their technical dept if shear strength is important to your application..
  • theoldwizard1 wrote:
    Terryallan wrote:
    This could give you a starting place on buying Azdel. Also google, ...
    I have googled Azdel every which way I can think of. Most place just praise the product. Some are wholesale distributor (not looking for a semi load).
    This one is selling left over/over stock panels, but at an excellent price !
    Azdel Composite Panels 4x8 - $13 (GLASSBORO)
    I found it on Bing. and as i say. the plant is in Shelby NC. Give them a call.
  • This could give you a starting place on buying Azdel.. Also google, or Bing, azdel for sale. It just happens to be made a couple towns over in Shelby NC.
    Azdel Composite Panels 4x8 - $13 (GLASSBORO) | Materials ...
    https://www.shoppok.com/southjersey/a,37,175767...
    Products - Hanwha Azdel
    https://www.azdel.com/products.html
    Showroom | AZDEL Inc. CompositesWorld
    https://www.compositesworld.com/suppliers/azdelva
    https://robertweedcorp.com/products/azdel-composite-panels/
    Azdel 48" x 96" Sheets of 2.7mm Boards (6,000 Sheets) | Salvex
    https://www.salvex.com/listings/listing_detail.cfm?aucID=182964932
    Azdel Onboard | Composite Panels for RV Construction | No ...
    https://www.azdelonboard.com
  • FRP Fiber reinforced panel would be my first thought. The panels are available in 4'x8' panels and are totally waterproof. I had them in my car wash for 8 years with no problems.
    I cant remember what the price was, but they are not cheap, at least the version (white pebble finish) that I had. They are commonly used in commercial kitchens, medical facilities and farms.
    Maybe this would give you some ideas. Panels
    There are also some pvc based products.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
