Vintage465's avatar
Jul 06, 2019
Back up lights
My 2015 Creek Side did not come with back up lights. I intercepted the 7 wire cable at the front of the coach with a 4x4 weather proof box. The seven wire comes out to the left to the left. The Seven wire continues up into the coach thru the top of the box. The conduit(emt)comes out toward us in the pick and makes a right hand turn at the frame.
'Bout half way down the coach I installed a weather proof 2x4 box to add side lumination when the back up lights come on. Nice for late night arrivals.
This is the little light for side lumination. There is a matching one on the other side of the coach. You can see the LB I installed to facilitate a conduit tap to go to the other side of the coach.
I mounted the back up lights to the bottom of my tool boxes. Ran conduit across the back of the coach. Put another 2x4 weather proof box to drop the wire out for the left b/u light.
This is a close up. These lights are 1250 lumens and cost $44.00 from Northern Tools. The side lights are 1050 lumens and cost $15.00 from Northern. The back ones are so much better. I may change the side ones when I get a few other projects done.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,421 PostsLatest Activity: Sep 24, 2026
