GordonThree's avatar
GordonThree
"backup" light
I picked up a cheap LED flood light, 27 watts (100 watt equiv), that I would like to mount on the rear of the trailer somehow, in as non-invasive manner as is possible (no drilling). My plan is to use it for some extra visibility backing up if I get stuck out after dark.
The fixture comes with a basic C shaped bracket designed to be bolted onto something.
suggestions?
I plan to provide it a dedicated fused and switched power lead, rather than taping into the trailer's safety lighting.
  • Try the Command adhesive strips that you can buy almost anywhere.
    Those things seem to hold pretty darn good.
    I'm not sure how they would handle the outside elements tho.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
