wanderingaimles
Oct 17, 2018Explorer
On my s&b the faucet is a price Phister with that same problem. I ended up using the valve in the cold water supply line to throttle back so the flow on the cold is reduced.
In a 5er you will likely have to add a valve for that.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
