DutchmenSport
Oct 17, 2018Explorer
Once again, thanks for everyone's suggestions.
I ended up pulling the faucet handle, disconnecting both hot and cold water line, and flipping the faucet handle up-side-down. What that means is, the cold is going in the hot side, and the hot is going in the cold side.
When rotating the handle now, it starts off hot and the farther it turns it gets colder, just the opposite of the way it use to work.
And yes, the water is now nice and HOT! It's still not scalding, but it's definitely HOT now, and flip it all the way around and it's cold.
Before doing this I talked with the DW and we both agreed, when we first turn the shower on, it always starts off with cold water from sitting in the lines and usually takes a minute before it gets hot anyway (that how our last trailer functioned). So as long as we are aware of this, we've got no problems using it this way.
We very seldom have guests, maybe our son and grandson who come with us occasionally. They will just have to be taught to use it this way.
Problem solved! No extra plumbing required, except to unhook and hook back up the line.
And, an extra benefit...The shower hose now hangs down and loops up to it's holder. When it was turned the other way, the hose was coming out of the knob thingie straight up, causing the hose to snake around and twist. Now it hangs nice and straight.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
