westend
Oct 06, 2016Explorer
Yeah, sometimes the fridges have an electrical schematic on the back cover or close to the compressor, below.
If you have a Meanwell that is adjustable, I'd suggest to just use that for charging and do it at a higher voltage than 15.2V. 15.5V-> 16V would be a good range. When equalizing do it at the top of that range. GC2 6V's do a lot better when they are pushed with a higher voltage. IIRC, Trojan specifies 16V or above for equalization.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
