Doclocke's avatar
Doclocke
Battery Meter
The battery status display in our motorhome leaves a lot to be desired, and I've found through experience that I can't trust it when it comes to knowing if the shore cord needs to be attached during winter storage.
I'd like to install a small dial that would be be directly wired to the battery terminals, with an on/off switch to prevent the meter itself from using juice when I don't need it.
Have any of you guys done something like that? If so, where did you find the meter?
Thanks for any suggestions.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
