The battery status display in our motorhome leaves a lot to be desired, and I've found through experience that I can't trust it when it comes to knowing if the shore cord needs to be attached during w...
I have installed a BM2 from ebay. No local display but it is bluetooth to your phone. You can check you voltage from bed and it has data logging that allows you to see your voltage on a graph.
This past weekend I knew from bed that my batteries had died at 3 am for some reason. That reason turned out to be low water.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
