Alan50
Feb 29, 2016Explorer
Battery move
I'm sure that this has been beat in one way or another. I've got a battery problem, in that other people think they need them worse then I do. first one cut stolen and ran with it.. next one clipped ...
Alan50 wrote:myredracer wrote:
I did this in a previous TT. Originally had a length of vertical luan plywood and front cap was very curved so had wasted space. Only for one battery but could done a pair. Had the original lead acid battery at first and plan was to go with an AGM eventually. AGMs can off-gas if overcharged and I've read that it is a good idea to vent them. You can buy the vents, sealed/vented battery box and hose from an RV dealer or online.
If you hide that batteries inside, maybe it would be a good idea to leave the old empty battery box there along with cables so thieves won't try to get inside. Also, don't put them in a place where the ambient temp. can get high.
Is this Battery Vented to the outside other then just the hatches on the port and starboard sides? AGM battery?
