Darrah's avatar
Darrah
Battery Question?
I'm getting ready to start a campervan build and was thinking about the house battery(s) flooded or AGM
I've never used the AGM kind before.
So what do you guys think?
  • Thanks everyone for the information.
    It gives me something look into now.
  • Almot's avatar
    Almot
    Explorer III
    Sorry, didn't read the OP question in full :)
    It's a campervan, so the battery will be pretty much "inside". Separated from living quarters by some thin wall. I don't think you have any other choice but AGM. Here is my UPG $180. Can't tell about long-term performance. LIfespan is measured in cycles, not years. I didn't use it much since bought, so it's still good. Concorde/Lifeline of that size would cost $300.
    And, - yes, get at least 100 AH solar. AGM don't like to be incompletely charged every day, same as flooded. I have 500W solar, and very modest energy consumption, so they always charge fully by the evening.
  • Almot's avatar
    Almot
    Explorer III
    Darrah - we've been through this a few times this year, in Technical section. And every few months in all the previous years, since AGM - or this forum - came into existence. There are benefits to each type, depends on your particular situation.
    I have AGM by Chinese UB/UPG. Cost me $180 per 100 AH, 12V. They are cheaper than Deka, Full River or Lifeline (I think these 4 names is all that there is). There are cheaper brands yet, but those I wouldn't even call a "brand",. Flooded 6V cost $140 per 225AH, i.e. per 112 AH. Costco 6V are probably cheaper yet. Cost is not important if you treat your battery right, so it lasts 5 years or more, and your battery bank is not terribly big. You pay $60 or $80 more for AGM once in a while, no big deal. But, if you keep 500 AH bank and throw it away every couple of years, then it adds up quickly.
    My reason for AGM was - mostly - the need to keep it stored without charging. Solar system wasn't up yet, so they were just sitting there without maintenance charge for almost a year, losing 40% of charge. You can't do this with flooded, they will discharge down to zero in 4 months, you do this couple of times and then can throw it away.
    Also, flooded need watering. They lose water even if you leave them on trickle charge, and in several months could lose a lot.
    If and when I move to live in trailer fulltime, there is a good chance that I will get some cheap flooded.
    Another reason was - a possible location of batteries inside the trailer, in front pass-through storage. It's accessible from outside, but it's in fact under the bed - you lift the bed and here they are. AGM don't release toxic fumes or explosive hydrogen gas - very rarely, only if you severely overcharge them. It wouldn't be a good idea putting the flooded there.
    And there are other differences - important to some people and not important to others.
    AGM can take - usually - slightly higher charging current than flooded, and Lifeline AGM can take MUCH higher current.
    AGM would keep the voltage better under the load - voltage drops when you apply high loads, and in flooded it drops more than in AGM, some DC devices wouldn't work properly when voltage is too low.
    AGM you can't equalize - only Lifeline explains when and how to do this, other manufacturers just tell usual bullchit that AGM you "don't need" to equalize because are maintenance free. I think when my UPG will lose 15-20% of capacity, I will try boiling them at EQ voltage for an hour or so, even if there is nothing in the manual.
  • Hi,
    AGM battery is a lot more expensive than a lead acid battery, and tend to not last as many years. A well taken care of lead acid battery can last 10 years or so, while one that is ignored can go dead and dry out of water in 1 year. AGM should last 5-6 years.
    However in your case, with the additional cost of a leakproof and vented battery compartment, it would be less expensive to install a 100 amp hour AGM battery inside, than to build all that other stuff and use the lead acid battery.
    Is 100 amp hours enough? Well if you are using LED lights, and not watching a lot of TV, then you should be fine.
    You might also want to install a solar panel if you plan on dry camping much. 100 - 150 watts will keep that battery full all the time, unless you hook up a refrigerator to it. It will also shade about 20% of your roof surface, so it will seem like you are parked in a partly shaded space all the time.
    SunElec.com
    Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
