happycamper002
Jul 11, 2016Explorer
mabynack wrote:
I had problems with my 12 volt system on my FW and when I pulled the battery I found that it was only putting out 7 volts. The rig stays plugged in all the time.
A few weeks ago someone posted a thread about installing a permanently mounted voltmeter to monitor the battery. I purchased one and now I'm looking at installing it.
The question is - can I wire the positive terminal of the voltmeter to the battery monitor in the panel or should it go directly to the positive terminal of the battery?
I have four individually monitored batteries on my Class A rig. I installed battery disconnects for each of the battery so I can check the voltage of each battery without getting a feedback when checking a particular battery. If you only have one battery, you wouldn't have to have multiple voltage monitors.
I can charge each of my battery through my solar panel or through my alternator if needed. I installed the voltage monitor(s) close to each battery. You did mention that you keep your rig plugged-in which means your charging system is capable of switching (you wish) to trickle mode whenever the charge is complete. This is where most of the problem occurs where the battery gets overcharged if left plugged-in indefinitely. I've had this problem which prompted me to install voltage monitors. In your case, you have a 7 volt reading despite being plugged-in which tells me that the battery is probably sulphated--rendering it unchargeable.
The charge voltage from your coach converter puts out 18 to 20 volts which is hard on your battery plates if it fails to switch to trickle mode. It's a good idea to have a voltage monitor but keep in mind that even small gadget will draw power from your battery. To solve this problem I installed a momentary switch so it's not on all the time. A properly charged battery should read anywhere between 12.3 volts to 12.7 volts. If you decide to hook it up directly to the battery, it's a good idea to install a 5 amp fuse just in case there is a short.
From sunny California
V.A Vasquez
Retired Electrical Engineer, Computer Data Network Engineer, Electrical Contractor.
1986 Bounder Class A, 24-year Good Sam Lifetime Member.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
