BarneyS
Jul 11, 2016Nomad
mabynack wrote:
It's a pretty good run from the panel to the battery, so I was hoping to just run it to the sensor.
My sensor still had all the lights illuminated when the battery voltage was only 7 volts.
Thanks for your inputs. I'll try hooking it up to the panel and see what happens.
If you are talking about the sensor panel that has the lights for the holding tank levels, and the battery condition, it will always say full battery and light up all the lights anytime the trailer is plugged into the shore power. That battery indicator is only good when the trailer is on battery power.
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
