time2roll
Jul 11, 2016Nomad
You can connect where you like. It will read voltage at the point of connection. If all is good then all points have pretty much the same voltage.
Still if the battery is bad the converter may hold 13.2 to 13.6 volts and you don't know the difference. Need to unplug now and then to get independent battery voltage.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
