JWRoberts
Jul 12, 2016Explorer
Bill.Satellite wrote:JWRoberts wrote:
There will be NO difference in readings at the battery or the panel.
There certainly can be differences depending upon the coach wiring. The OP will need to give the easy option a try but if that's not accurate the OP will need to find a better option.
As a retired electrical engineer, I assure you there will be NO difference. A digital meter draws micro amps of current from the measuring point so no significant voltage drop will exist.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
