Chuck_thehammer
Jul 12, 2016Explorer
on my trailer... 30 foot.. battery in the nose and panel behind rear axle .
main wire run. is 35 feet.. with a steady draw of 20 amps. I have a 0.5 volt drop from battery to panel.. and my unit is 11 years old.
and I am using a Fluke meter. accurate to 0.002 volts.
but the drop is normal and within specs.. look on the web, for voltage drop for 12 volts an its different than 120 volts... ac and dc...
low voltage DC is harder to travel in wire.
that is why the world uses AC in everywhere... power loss in wire.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
