bpounds
Jul 20, 2016Nomad
+1 Mr Wizard.
You can see it readily on the meter. Watch it while your generator is running, then cut the power. The voltage will drop immediately, then taper downward. You can watch it, and within an hour or less it will have stabilized. I do agree that it is still artificially high and is not a true indicator of amps available. But that does not mean it has no value. You will definitely know when you need to run the genset again to prevent excessive discharge.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
