Merrykalia wrote:
I have no idea if this would work, but it is the first thing that came to mind when I read this. How about installing casters that would take the weight of the bed off the floor. Use some blocks of wood to attach to the inside of the fram and attach the casters to the wood blocks. You would be able to determine where you need to mount the blocks for the height of the casters that you choose.
Thanks for the idea, I will take it one step further, with this suggestion I came up with a V groove wheel and track on each side of the bed, basically the same set up they use for gates that slide side to side. That way it keeps it straight and will keep the weight off of the carpet. I still need to go find the parts and figure out how to support them but if it works I will post some pictures.
Thanks again.
