CA_Traveler
Dec 12, 2020Explorer III
That's a lot of information and RV updates. My solar equipment is mounted on a side wall of the basement storage and hence it takes no storage space. One small cable comes up to a remote monitor and the second cable is for the laptop to track more detailed solar performance when desired.
Hope you have a plan on how to park because the A/C shadow will reduce your panel output. Are you going to tilt the panels or is flat mounted adequate?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
