Almot
Jan 01, 2016Explorer III
Veebyes wrote:
A boaters mind coming at you. From what you say the roof seems to be in good shape & already coated with epoxy. By that I assume epoxy resin as used in boats. Tough stuff.
I had a boat with a cockpit deck constructed much the same way. Topcoat used was epoxy paint.
Yep. Epoxy is tough. But UV kills it, that's why it's important to paint it over. 100% acrylic latex paint works well. Won't last same long as epoxy paint, but it's so much cheaper that it pays off eventually. When epoxied ply starts deteriorating, it's usually at the edges or damages/imperfections on the surface. If it still looks intact, I wouldn't bother with EPDM.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
