Almot's avatar
Almot
Explorer III
May 17, 2023
Better/brighter interior bulbs?
Long time ago replaced interior incandescent bulbs with SMD LED boards with 10mm wedge base, ~20W equivalent, ~320 lumens. Was happy, now want something brighter but can't find anything more powerful in this form-factor. Here is a typical offer, scroll down to specs with 24 LED: board 4.4 cm diameter, 370 lumens: 24-5050 SMD
Double pancake dome light would probably accommodate a larger diameter board, but I can't find any. Don't want to overpay for a whole new fixture when just the "bulb" needs replacement. Or should I give up the idea of a wedge base fixed rigidly to the SMD, and look for a rectangular board like 48-5050, with wedge base dangling on the wire. Can such a board be drilled through, to attach it to the dome fixture, did anybody try?
I prefer a board, not a "cob", because a cob would have 30-40% of LED diodes illuminating the ceiling behind them. Any suggestions are welcome.
PS: would be nice to find a source with proven quality. Ebay is huge same as the China itself and full of cr-ap, with some more reliable sellers like the one in the link.
  • We've had great luck with m4 -- they are located in the US and they answer questions quickly and correctly. More expensive than "straight outta China," but much more reliable and trustworthy:
    m4 LEDs
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 19, 2025
