Dutch_12078
Oct 13, 2014Explorer III
MC9 wrote:
This is a 2013 model so everything works as good as most. But, the faucets,showers and such aren't exactly power washers, like the S&B. Just looking to beef it up some.
Higher flow won't give you more pressure, just more volume. Your fixtures are limited to 2.2GPM at 60PSI by the EPA, so unless you open several faucets at once, a higher flow pump won't make any difference. Depending on the pump model you have, you may be able to boost the pressure a bit using the adjustable pressure switch on the pump. Otherwise, you'll need a higher pressure pump.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
