qttire1's avatar
qttire1
Black tank new valve location
My black tank valve won’t close. It’s all the way up under by the black tank and very hard to get as I have added some things under the trailer. Has anyone just left this one open and added a new valve by the pull  handle and use that one as the main one instead of changing the old one out. I was thinking of cutting the cap off and adding a new valtera valve at the end and not have to worry about the cables anymore.
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    Well then you are either going to have to replace the original valve or add another in-line.  Mine is inside a small cubby and a real pain to get to, but I've done it twice to clear the gate path so it would close all the way.  Not easy, but it can be done.
    • qttire1's avatar
      qttire1
      I have that now but it does not tighten down very well and when you hook up a hose to it comes off easy and afraid it will happen when full. Looking for a more secure fit
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
