GordonThree
Apr 07, 2016Explorer
djgodden wrote:
So, I take it having both the charge controller and the converter charging the batteries simultaneously isn't an issue? The whole reason to have a charge controller is to allow maximum efficiency in charging the batteries. Is the convertor just as efficient? It just feels contradictory.
Whichever charger holds the higher output voltage will be doing the charging, as higher voltage allows it to deliver higher current.
If you're on shore power, and your batteries are charged, your solar controller isn't going to supply much DC power, even in good sun. Your converter will be holding the DC voltage high, keeping the solar controller on standby or in float mode.
If you've just plugged into shore power (or started your generator), after several cloudy days, running the batteries down, both the converter and solar should both provide charging to the batteries. This is because the depleted batteries will hold the DC voltage low while in bulk and absorb states. This is assuming the typical 30-40 amp factory converter.
When the batteries get to ~85-90 percent and enter the float state, this is an unknown area. Both the converter and solar will want to enter a float charge mode, I guess whichever has the higher float voltage will "win" and the other will go into standby.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
