Housted
Dec 11, 2013Explorer III
PaFruMan wrote:
@ Housted I guess u mean 12400 lbs so 5.6 to right? (We Europeans work with metric units...)
Lifting the whole RV just for $2000 is great!
Have u noticed some stability problems. I read in some forums that, lifting the whole vehicle by jacks at remote places can cause a permanent deformation of the frame.
Paul
I have a Northwood 5er which has a very substantial frame. I have not noticed any stability problems using the leveling system. We have been in campsites that had one side off the ground and the wheels would turn freely. No problem. Yes I meant 12400 pounds. I modified the system to turn off the back jacks with a push button, so when I use the remote to hook/unhook I use the all up/all down buttons to raise/lower the pin.
Housted
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 22, 2026
