nineoaks2004
May 14, 2016Explorer
I think the deck should be made out of pressure treated lumber or deck boards. If you use PT lumber do not leave a gap when screwed down, as the decking will shrink and leave a gap, if you do leave a gap it will entirely too wide when the boards shrink. Above ground probably does not need to be treated if painted, or stained..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
