haydoracin
May 15, 2016Explorer
1ofmany wrote:nineoaks2004 wrote:The problem with NOT leaving a gap between deck boards is that they also can swell and then with no gap will buckle.
I think the deck should be made out of pressure treated lumber or deck boards. If you use PT lumber do not leave a gap when screwed down, as the decking will shrink and leave a gap, if you do leave a gap it will entirely too wide when the boards shrink. Above ground probably does not need to be treated if painted, or stained..
I've built a lot of decks over the years with pressure treated wood and never once had a problem from swelling. Guaranteed they will shrink, and become very crooked if you don't use them quickly.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
