- Here's a little more detail on the crimpers: Unboxing video / intro
- I have quite a few pieces of cable left over from adding inverters to all my RVs, so it was time to buy my own crimper and make use of the cable I've had on hand.
Super_Dave wrote:
About any size, any length, any termination.
I go to Amazon and buy cables already made up in 1' increments.
https://www.genuinedealz.com/collections/custom-cables- Timmo_Explorer III'm in the "go to welding shop" camp. Had to create a "cable manifold" of sorts when I went with a pair of 6 volt golf cart batteries. Went with the biggest gauge they had. LOL, they charged me a 12 pack of beer.
- Super_DaveExplorer III go to Amazon and buy cables already made up in 1' increments.
- duplicate
philh wrote:
how many amps are you running thought that cable, a bazillion?
Nope, more. Eleventy-billion
The large cables are for my Victron Inverter project- philhExplorer IIIhow many amps are you running thought that cable, a bazillion?
- richardcoxidExplorer IIYou can also go to your local wholesale/retail welding equipment dealer and use industrial quality welding cable/terminals.
The dealer will have many gages (reels even) of black welding cable and a selection of terminals. Welding cable is very fine strands which are more flexible than standard automotive battery cable and the insulation is also very flexible and resistant to abrasion/chemicals. As well as a assortment of shrink fit.
Most suppliers will for a small $ amount crimp on the terminals and apply shrink fit etc.
Remember, measure TWICE and CUT ONCE!
Also if you have a scrap of steel approximately 1inch by 2 inch wide by 6 or 8 inches long available, drill a 3/4 to 1 inch diameter hole close to one end (must be large enough for the widest end of the terminal to pass thru) then drill and tap a 1/4 - 20 or a 5/16 - 18 hole 90* from the center line of the big hole. Clamp your tool in your shop vice, prepare one end of the welding cable/terminal place it thru the large hole, tighten the bolt and you have hand dimple clamped the terminal to the cable. (looks better than the “old” chisel/hammer method) - GaryUTExplorer III clamp the crimper to the workbench with quick-grip clamps. Put the terminal in the crimper and tighten it just enough to hold the terminal without smashing it. Hold the cable in the terminal and crimp it with your other hand.
Putting the terminal in the crimper first also makes adding a terminal to a cable that's already in place on the trailer.
Gary
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
