down_home
Aug 07, 2013Explorer II
down home wrote:I take back the screw in part. It turns to lock and folds down internally on the cap or cover. It does not screw in. It has a big o ring between the flange and cap.
Freightliner has a ring and screw in cap for the sewer hose. I'm not near the motorhome to get a measurement but if you can get the sewer hose down though it with plenty of room to spare it should work fine. It attaches with several screws around the ring. The ring is internally threaded for the screw in cap or cover. It has a pop up handle to help unscrew it and it is gasketed. The cost was between 30 and 60 dollars.
It is substantial construction.
You can order from the factory parts department.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
