Almot
Jan 30, 2017Explorer III
urbanMark wrote:
...the one remaining task is to route the cables from the roof to the controller. My fridge is near the rear of the trailer, so that isn't an option
Not an option because ....? Too long run or don't know how to route it inside in aesthetically pleasing way?
Voltage drop with 24V panels in series isn't a big issue, with #10 MC4 cable (you cut it in half) at 30-40ft run V-drop will be negligible. With more than 500W or in parallel - can't say, need to run the numbers. There are also #8 MC4 extensions for those who need it.
I did it this way with 2*250W in series, #10 MC4. About 18 ft from fridge vent to trailer front, inside routing through the wall cabinets, and then under the Wiremold cable covers when not in the cabinets. 7ft drop down to batteries plus another 5 ft interconnect btw two panels, total 30ft one way. According to Southwire calculator this results in less than 2% voltage drop.
There isn't much need to drill the roof with 24V panels. With 12V panels and PWM - yes, those are often installed with a hole in the roof and junction box.
Yes, somebody run it through the black tank vent - not the grey tank, as I recall - doesn't matter, it's not venting to inside anyway. Pics are posted on that List.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
