GaryS1953's avatar
Mar 07, 2017
Solar panel cable routing
Hi All - I have a small 25'5th wheel to which I am adding solar panels. I've already upgraded my batteries to 2 GC2 6 volts in series. The batteries reside in boxes on a rack under the 5th wheel overhang. I'm trying to figures out the best way to route the wiring. I'm going with an MPPT charge controller which needs to be inside the unit, so obviously the wiring needs to get from the panels to the charge controller, then from there to the batteries. Getting from the charge controller to batteries is relatively easy as I would mount it on the interior wall with the batteries on the other side and just drill a hole for the wiring. The question is how do I get the wiring from the panels to the charge controller? I've seen people talk about going down one of the vent pipes, but those are at the rear of the camper with no easy path to get from there to the front wall. Any ideas? Any help is appreciated.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
