Bobbo
Aug 22, 2017Explorer III
bartlettj wrote:
It's ok if you have another external vent for the tank it feeds. If you don't, you are asking for trouble. The AAV has a one way valve that only allows suction to replace the air that went down the drain with the water, so if pressure builds up in the tank, it won't vent it. Any tank pressure will bubble through the trap unless you have a rooftop vent.
Very good point, and important!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
