westend
May 26, 2013Explorer
There should be no problem using a standard RV converter/charger and I would think a bigger one would be the best choice, something bigger than 60 amps. That will allow for a quick recharge to 90% of capacity.
The winch and landing gear will be using the reserve power of the batteries along with assisted converter power if converter is powered with AC. No problems but remember to fuse wires correctly and use big wire.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
