Sushiholic11's avatar
Sushiholic11
Cargo Trailer Conversion - Propane Issue
I am in the middle of converting my 14x7 cargo trailer into a "toy hauler" travel trailer.
I want to hard pipe a quick connect line under the trailer to connect my firepit and/or gas grill.
I have done some reading and I think I understand the working of the propane system, stage 1 (tank to pipe) reduced pressure to around 10-15 psi and stage 2 (pipe to appliance) reduces pressure further to .5 psi.
My question is this, is the 10-15 psi first stage a readily available part? Am I way off base with my understanding? I know I cant run the .5 psi gas to my quick disconnect line as I will then need to remove my regulator on the appliance (which renders it useless anywhere else).
Any help would be appreciated.
Bob
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,367 PostsLatest Activity: Apr 30, 2025
