- Old-BiscuitExplorer III
NMDriver wrote:
Old-Biscuit wrote:
Residential oven/stove are NOT RV Appliances.
Also vintage of appliance comes into play....how old is this stove/oven?
MANY newer residential models are not converter-able as they are 'gas specific'
I did not STATE it was an RV appliance but it would fit into our 5er and it is definitely convertible.
"MANY" is not all and as I stated there are kits on line.
SOME current year stove models are Natural Gas and fit into the 20 in space of MOST RV's (Amana for one). I am sure if you google Natural Gas RV appliances you can find "MANY". Many being a relative term. The Amana comes with the LP conversion kit included BTW.
AS I stated. Converting is possible but generally not worth the money.
Off topic for OP......as it was about RV Appliances
Sure one can find some residential stove models that can be converted propane to gas/gas to propane
And some of those could be placed in an RV
But now you have a stove that works on natural gas and all other appliances still work only on propane.
Larger stand alone propane tank is best option for extended stays - drsteveExplorer
2112 wrote:
westend wrote:
X2
Old-Biscuit,
Please, don't ever leave the Forum. Your replies to appliance/gas/plumbing questions are the best!
X3 - NMDriverExplorer
AS I stated. Converting is possible but generally not worth the money. - ktmrfsExplorer IIIas others have said get a BIG propane tank. Virtually all home appliances can be set to run on either natural gas or propane with the proper orifices. That's because for sticks and bricks houses there are lots running on propane so the mfg have designed them to be dual fuel with the proper setup.
Same with BBQ's etc. our firepit and BBQ run on either, and we had them configured for NG. However a NG BBQ doesn't get quite as hot or heat as quick as the same unit on propane. big difference in energy content. The BTU rating on the firepit and BBQ is slightly lower on NG than on propane.
RV appliance are not that way. I have not seen any that can be converted to natural gas. - westendExplorer
Old-Biscuit wrote:
I have never seen an RV range with the extra set of gas orifices. I have changed out residential stove/oven orifices, like NMDriver states.NMDriver wrote:
We have a full size propane oven/stove in our shack in the hills. It came with jets for conversion to natural gas. They are setting in a tray under the range top. Our propane supplier said it is no big deal to switch the oven/stove to natural gas if we wanted to. For safety/liability sake it should be done by a trained tech although you can find instructions and kits on line.
Even so, it is way easier, but not cheaper, to get a larger supply bottle.
Gas specific sounds about right. It is just an extra cost to the Mfg to setup a dual-fuel alternative and there could be parts that do not work well with a different gas fuel. - Old-BiscuitExplorer III
MANY newer residential models are not converter-able as they are 'gas specific' - ScottGNomad
2112 wrote:
westend wrote:
X2
Old-Biscuit,
X3 and he is able to post these helpful bits without the level condescension and rudeness some others here seem to have to employ. - ScottiemomNomad III had major back surgery in March. Knowing we were going to get cold in Indianapolis in March, DH bought an "extend-a-stay" for on the propane tank on our Phaeton motorhome. He purchased a 30-lb tank, filled it and set it outside by the coach. In the two months we were sitting still, he had to fill it 2 more times, but preserved our on-board propane. We drew off the auxiliary tank only. We didn't want to move the coach to go get propane because I could not help with anything. It worked perfectly.
I do think having the larger tank placed would be the answer. And then have it filled by a propane delivery company.
Dale - 2112Explorer II
westend wrote:
X2
Old-Biscuit,
Please, don't ever leave the Forum. Your replies to appliance/gas/plumbing questions are the best! - edatlantaExplorer III use a 150 gallon (yes gallon, not pound) external propane tank and have it filled typically twice each winter. I hook it in to my RV propane system right after the onboard regulator since the external tank has it's own regulator. I did have the propane company check the pressure on the external tank when I first started using it during the winter. Works great.
