Dernhelm's avatar
Dernhelm
Ceramic Heater Safety
Not sure where I should post this; please feel free to move it? I did a forum search for the subject, but couldn't find it.
Basically, I'm looking for a supplemental space heater that's "safe" to use in a trailer. By "safe" I mean it has a tipover switch, an overheat switch and if your dog wags his fluffy tail against it, it might not ignite.
Do "ceramic" heaters fit the bill?
  • jkwilson wrote:
    GDS-3950BH wrote:
    Don't worry about the dog. Once his tail bursts into flames once you can rest assured he'll not go near that heater again.
    I hope you are happy!
    Your post has condemned me to hell as I snorted diet Mountain Dew laughing from thinking about a dachshund running around the camper with its tail on fire.
    LOL.
    We had a cat that had an unbreakable habit of jumping on the kitchen counter. One day he jumped and landed with his rear paw square on the burner of the flat ceramic cooktop. The burner was just shut off. He never jumped on the counter again after he hobbled around for a month with a huge bandage on his foot. It took about 5 years before he would jump up on anything, including a bay window, the bed, anything.
    On topic, I have not seen many electric heaters that do not have a tip over switch other than utility types, such as what they call milkroom heaters.
    Does that make him a "hot dog"? :W
  • RoyB's avatar
    RoyB
    Explorer II
    I use a couple of these low profile oil filled portable heaters...
    These have no open flame or red-hot cores to deal with. They have same BTU rating as the other heaters have... May take alittle bit longer to bring up the heat...
    Being low profile fits my OFF-ROAD POPUP trailer just right...
    Google image
    If I need to move some heated air around the room I can sit my O-2COOL 10-inch fan behind it...
    Works good for us...
    Roy Ken
  • Electric heaters are nice except you need to run the RV's propane heater to keep the tanks from freezing if it gets really cold.
  • Pick one up at Walmart. But like you said, make sure it has a tip-over switch. Many don't now, just an overheat, which I would not trust. The overheat is good if something should fall and block airflow around it.
  • Don't worry about the dog. Once his tail bursts into flames once you can rest assured he'll not go near that heater again.
  • bukhrn's avatar
    bukhrn
    Explorer III
    Yes,the ceramic heater I use, and all others I've seen have the safety features you mention, Tip Over Shutoff switch, over heat switch, I'm not sure your dog will burst into flames just by wagging his tail against it, I always put it where the Dachshund can't get at it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
