sch911
Jan 04, 2015Explorer
Any flat screen flush mount bracket (there are hundreds out there) will work. Keep in mind that all flat screen TV's have a built in standard mounting system that uses 4 screws in a square pattern 100 mm apart on the back of the TV. That's where the bracket attaches. Also, you'll have to "build out" the area behind the TV to make any of these brackets work correctly.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
