Albertaguy
Jan 05, 2015Explorer
I have taken 3 pictures of my unit but for the life of me I can't see how to post the pics here.
I have a 2007 Jayco Eagle bunkhouse model with the entertainment center on one wall which is hidden when the living room slide is in. There is a picture frame around the 32" TV and my idea is to remove the frame and find a bracket that will or open about 36". There will be a bracket at top top and one at the bottom mounted to the frame which is plenty strong enough. There will be two mounting straps that mount on the back of the TV and then mounted to the 36" bracket. The flatscreen will be removed when traveling. I will then have to find a filler at either the bottom of the flatscreen or divide it by two and put a filler at the top and bottom. I need to fill about 4 inches. Because of my slide I need to have this mod as close to the wall or entertainment center as possible. The 36 inch bracket is the only thing I need to find. I would rather buy a bracket then to try to make one.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
