Albertaguy
Jan 06, 2015Explorer
Johno02 wrote:
First, look at the sticky in the Technical support forum for how to upload and post pictures, is't really very easy. Second, is your current TV mounted in a cabinet or shelf, with or without a frame around it?? If so, measure theinside of the frame, and use a LED screen that will fit in or behind the frame. Mount the new TV on its built in base with as much blocking to rais the screen to whever you need it. If necessary trim the front of the TV base to fit. replace frame around, and add fillers above and below as needed. If you need PM me and I will send pictures of my modifications.
I see what you are saying. My TV is mounted in a cabinet and any TV that would fit in the hole is just too small. I still think my idea is a better option as long as I can find a 36 inch bracket. I tried to figure out how to post pics from the sticky but I guess I am just too stupid because it won't work for me.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
