rickst29
Apr 18, 2016Explorer
https://goo.gl/photos/DBtjLwMrpZ8sjmLYA
Here's a note on the Tow Vehicle Picture: There are 3 Relays (rather than two), because I didn't have access to the original "Trailer Battery Charge wire" under the hood, after the fuse. It's hidden within a gigantic bundle.
So, before the two 12/24 "switching" Relays, there is (1) a direct battery connection with a new fuse (30A), and (2) an initial Relay, which switches "on" whenever the engine is actually running.(My new Trailer Battery Charge" circuit is not activated by merely turning on "accessories".) I pulled the fuse for the OEM circuit.
Meanwhile, in the Trailer: the schematic shows 3 Relays, allowing for an automatic switch of "Bargman 12V" back into the "+12V" power distribution, whenever the 24V coil Relay is not activated. But per above, we never want this if:
- The Trailer will never be pulled by a different, 12V-only Tow vehicle; and
- You can always remember to flick the "24V mode" switch when pulling the Trailer, and sun conditions aren't perfect.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
