TakingThe5th
May 22, 2013Explorer
mbopp wrote:
What truck / trailer combination do you have? 7-pin trailer connections have a pin for a charge line and it can be wired to the battery and charged off the truck.
X2. You also need that battery to be in the trailer if you have electric brakes with the breakaway switch. Then if you accidentally disconnect - the battery will be used to apply the brakes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
